4. Unzip both of the files you downloaded in Step 3 to your desktop. Then run BC_VUP_v2.0.0.7.exe to install the firmware updater. (If you previously installed a version of BC_VUP, be sure you delete the old install files before reinstalling. These files are in a "BCSS" directory.)
5. Run the BC_VUP application you installed in Step 4. Follow all on-screen instructions. If you are updating from version prior to V3.00.00 you must enter the V3 Registration Key when prompted. If you are updating from V3.00.00 or 3.01.00 to this version, you do not need to enter the key. When prompted, select the BCD996T_V3_02_00.scn file you unzipped in Step 4.
If your having problems check these 4 things:
1. You must use the front port to apply all updates. The rear port DOES NOT work for firmware updates.
2. This update is cumulative...it incorporates all improvements made in all previous updates.
3. You must have applied the v1.04.12 update, prior to applying any of these updates.
4. You must have entered your ESN and ESN Checksum on the My Uniden web site A N D received a Registration Key for this update on the Myuniden.com website. This key will not be the same as the key used for any version like this V2.x!
