Upgrading XP7350E radios with old firmware
blhar15
Waterloo, IA
I have some XPR7350E's that have not been updated for a few years and still under the older CPS and firmware. I am not able to update firmware with the newer CPS 2.0. What I have seen is I need to update to the latest firmware prior to the switch to CPS 2.0, but you are not able to find that on the Motorola website anymore.
Any suggestions on this, am I thinking this correct?
K2NEC
NA
You need to do 2.09 to 2.10 and then you can upgrade to anything past that. But I warn you that if you don't need to upgrade to 2.10, you probably shouldn't.
blhar15
Waterloo, IA
The oldest version I can still download from Motorola is 2.110.120.0. So not sure where I get 2.09.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
That's the CPS version not firmware. 2.09 is not on there.
You would need MOTOTRBO CPS 16.0 Build 828 (Standalone) first then download MOTOTRBO NA Commercial Devices Release R02.10.10 and flash the radio. After that you will need to use CPS 2.0 and pay for/apply a SUM (Software Update Management) license to the radio, then you can update to the latest firmware, MOTOTRBO NA Commercial Devices Release M2021.03 or perhaps older if a radio is not an 'e' model.
As K2NEC said, unless you need to upgrade you probably shouldn't. Most people prefer to stick with CPS 16 and it's final firmware revision 2.09
blhar15
Waterloo, IA
Did you mean the MOTOTRBO NA Professional Devices Release R02.10.10, because that has the XPR7000e series radio in it. The Commercial Device Release only lists the CP200 and SL300. Thanks
blhar15
Waterloo, IA
I have the CPS 16.0 build 828 installed now and also installed the Release R02.10.10. However when I go to the CPS and try to update it gives me a message that no matching packages exist.
K2NEC
NA
Did you install the firmware packages? And you still haven't answered  why you want to upgrade the firmware
blhar15
Waterloo, IA
Yes, I installed the firmware pacakges and I am going to sell these radios so want to make sure they are updated and cleaned up. I need to reset to factory settings.
blhar15
Waterloo, IA
Yeah, I tried that also, same error, no matching packages exist. I am just deleting all the contacts, channels etc. manually. Thanks
redbeard
BEE00.348-3.1
Yes sorry I got the Commercial and Professional series backwards. And again, I'd take K2NEC's advice. They are worth more used with 2.09 or less in them.
Firebuff880
Boynton Beach, FL
Not compatible -- You need at R2.09. build if you want CPS 16..0 Build 828 Otherwise, you need a CPS2_2.18.95.0 or Newer.
CPS will support older firmware as it's mostly backward compatible, whereas it will never support newer firmware.
otobmark
NC
If I was able to program radio then I would just make a new simple codeplug with a few simplex channels, radio ID to 1 and reshoot radio for purposes of cleaning up radio for sale. Deleting anything from existing plug is tediously slow so just make new from scratch.
blhar15
Waterloo, IA
I appreciate the input on this. I just went ahead and created a simple codeplug for them. I had CPS 16 828, but my firmware was older, so I must have at some point needed to upgrade to newer firmware when they still had it available. I have not looked at these radios for probably four years or so.
redbeard
BEE00.348-3.1
You can't do that on MotoTRBO unless you saved the original codeplug somewhere or do a recovery.
