When registering, after you select "Radio Scanners" the page reloads and prompts you to select the model to register. If you are not looking closely, it could look like the page just reset, but there is a new prompt there.
UASD Installer InfoUASD Installer Ver 1.10
Don't forget that UASD was never updated to account for rebanded systems.UPMan if still around, what is the UASD Installer Ver 1.10 and is it
needed? My computer; Windows 7 Pro. FYI, all else went perfectly
on the BCD396T. Firmware at 3.02.02. Unit still uploads very slow
but when done work just fine. Memory @ 42%
Baud rate in the unit defaults to 115200 bps,
computer same. Unit at 45%. All loads fine
but extremely slow. Don't have that issue with
the BCD996XT, P2, etc.
To use Freescan to download trunk systems to your scanner, don't you need to have a premium subscription to RR?
While it's certainly easier to use web imports for programming via software if you are a Premium Subscriber, don' forget that FreeSCAN has EZ-Grab. You'll see the button to use it at the group level on a system. It's made to copy information from a web page, then you can define the field where that data goes. It may take a little practice on your part to use, but it does work.To use Freescan to download trunk systems to your scanner, don't you need to have a premium subscription to RR?
N0UDG - Yes I have the USB cable with the 'bulge' and
the proper driver installed. Earlier in the thread someone
else stated they had the same 'extreme slow' upload issue.
Again, doesn't happen with any other model. It does start off
at normal speed then about half way drops to a crawl.
Definitely odd but can live with it. When done, works great... Thanks
