Upper Base Frequency Calculation Question For UPMan
ProScan
Software Provider
Ontario, Calif.
UPMan
In Memoriam
Arlington, TX
In the calculator, you always need to input the table from lowest offset to highest. That will yield:
Code:
	      Lower Base	Upper Base	Step	Offset
Band Plan 1	851.0125	861.9875	25	0
Band Plan 2	851.0250	859.0000	25	440
Since public safety stops at 854, you can use any value of 854 or higher (up to 859) as the upper base.
ProScan
Software Provider
Ontario, Calif.
Code:
I got it. Thanks
