friendlybob
I have some of the Talkgroup numbers and I'm trying to get more so I don't bother the Admins with posting them to the database in bits and pieces. They're hard to catch.
Did you purchase the DMR upgrade on each of your SDS's? They don't track DMR right out of the boxSo what did you program in your scanner? I can't get anything to come in on these frequencies and I work out here!! Thank you in advance for ANY help. I have Uniden SDS 100's and SDS 200's
The Radio Reference database shows TG 16777056 has been reported as a "systemwide" talkgroup, which might include the site at Granite City, IL. Are you certain that the tone-outs you're hearing on that TG are for the Indiana sites? Also, are you hearing traffic on talkgroups like 1001, 2001 or 3001? Those are the fire and security TGs that have been discovered for the Indiana sites, could one of those (or other talkgroups in that range) be the "Emergency Band" you're referring to?Thank you much for all of your help!! I finally got to where I'm hearing everything with the exception of their "Emergency Band". When they have a fire or ambulance call, they immediately switch to this and I haven't found it yet. I'll keep monitoring and using Close call and other tools to try to track it down. If/when I do, I will certainly share it. They have an ambulance call as we speak! The only TGID's they use I've found is the ones listed already. The 16777056 is for the dispatch tones for and ambulance and fire call. After the tones, they give location and nature of call, then switch to the emergency band. Thanks again for everyone's help!! Happy Listening!!
Blessings, Bob.
I was thinking something along those same lines earlier, that it could be a conventional VHF (biz band?) freq that the local FDs, etc. would have programmed in their radios.Food for thought, the "Emergency Band" could be a conventional channel on site if local public safety resources that would respond have UHF capabilities (Conventional, not DMR). That may be the time for close call or a search of the 450 and 460MHz bands.
The Radio Reference database shows TG 16777056 has been reported as a "systemwide" talkgroup"
16777056 is not a valid TG number. TGs only go up to 65xxx, for any P25 system.
This system is a DMR Tier 3 system![]()
Are you pointing out facts again? 😄
