USB-C Power Upgrade Delivers A Whopping 240W For Gaming Laptops And Other Devices
tweiss3
Is it time for Coffee?
Ohio
I believe that USB-C is only 5 volts, there is also a commercial version that is 9v, but none are 12/13.5V, which is what almost all transceivers are designed on.
AK9R
Staff member
Super Moderator
Central Indiana
The amateur radio handhelds in my collection run on 7.2 to 12 volts DC so your USB C charging cable would need a boost converter to have enough voltage to charge the battery.
FranzSRC
USB-C has multiple modes, USB-PD standard allows many voltages to be used, the default I believe is 5V 500mA but it support 5, 9, 12, 15, 20V and 20v5a for 100w, some devices have special modes upto 40V but those are not USB-IF spec.
They use variable resistance over a handshake to determine the mode and that mode is a specific voltage and amperage.
good read on USB-PD specs on the tech sheets.
Explains the issues with the resistance, mostly about USB-A to USB-C cables.
merlin
DN32su
Not much new with the connector, standard equipment on Apple devices over a year now.
Doesn't matter how you plug it in, it is symmetrical.
The higher wattage means a wall wart to deliver it.
Try rapid charging a 30,000 Ma/Hr battery from USB - A it won't happen. (still takes 16 hours)
My Nano-VNA charges with USB-C, as does my porta-power from Anker.
Devices exchanging data you can expect faster with that.
