I use some of the Active USB extensions. Many of them allow you to daisy chain two of them together to get a distance near 130 feet.
I'm using three extensions made by Tripp-Lite I believe, they are chained together to make one long USB extension.
Amazon.com: Tripp Lite USB 2.0 Hi-Speed Active Extension Repeater Cable (A M/F) 20 Meter (65-ft.) (U026-20M) : Electronics That's just one example but several different makes of similar type active extensions are available including USB 3 types.
I have one of the orange Flight-aware SDR sticks plugged into this long extension inside an waterproof enclosure up on my roof. It works fantastic and allows for a super short coax run to the antenna which is only a few feet away from the flight aware SDR stick.
I did use a gel type stuff inside each of the cables connection points to keep out moisture. It's the same gel the phone companies use for making watertight connections in outdoor phone wiring pedestals. I do not recall what that gel is called but I've never had an issue from moisture anywhere along my USB extension runs. I think a decent dielectric grease will also work to weatherproof the USB connections.
The extensions I'm using are only USB 2.0 but none of my SDR sticks are USB 3 or higher so 2.0 speeds are just fine. I've never tried placing a small USB hub at the outdoor end so I have no idea if one active USB extension can handle more than one SDR stick or not.
These active extensions are all self powered from the hosts USB bus so I doubt they can support more than one typical SDR stick.
