justdmbobbo
- Joined
- May 31, 2004
- Messages
- 31
- Reaction score
- 4
I recently had my windows machine have a complete HD Failure - so I grabbed a spare drive off the shelf and spun up a copy of Linux/Ubuntu.
I have 5- RTL-SDR's in an external powered hub that worked without any issue on windows with the same guts (motherboard, memory etc). - only difference is now running Linux and not Windows.
Installed SDRTrunk and back up and running the same way I had the Windows version set up.
3-systems - 5 dongles
I seem to only be able to run things for 20-30 mins before I get USB I/O errors on one tunner... then it errors out... then a second and it errors out.
3-sticks always seem to stay solid.... but every time I restart, eventually 2 of 5 error out "USB ERROR"
I stumbled across this old thread here:
forums.radioreference.com
but I'm not quite following what adjustments I can make and the code to do so.
Can anyone give me a dummied down version of that thread or any suggestions?
SDRTrunk - SDRTrunk errors using 4x RTL-SDR receivers on Linux
I'm trying to monitor a few P25 systems with channels that are not closely spaced, requiring multiple RTL-SDR receivers to cover. I've found that when the 4th receiver is used (not a specific receiver, just the 4th simultaneous one to be brought up), I get USB errors such as: 23:20:44.861...
