Pro-106: USB Scanner/PC Interface Cable
mrchgr
Medora,IL
I have a Pro 106 scanner and the USB Scanner/PC Interface Cable and I have the scanner software on a nextbook Flexx10 (running Windows 10 Home). The software opens up and runs fine but I can't get the interface cable to work. I have installed the driver that I can find but nothing, when I plug the scanner in it just starts scanning what channels I have on it. Since it won't work on a MAC I need to see if I can get it to work on this. Is there something I'm doing wrong or just haven't found the right driver for the cable? Any help would be appreciated.
ScannerSK
Gilcrest, CO
I have a copy of the original driver that was included with my scanner from years ago which has always worked great. If you would like to give it a try send me a private message via RadioReference with your e-mail address.
Shawn
mrchgr
Medora,IL
I can try it but I still have the disc that came with my cable but its not working and I tried the one from the software.
mrchgr
Medora,IL
I still have the original disc that I got with the cable and I couldn't get that one to work, I also tried the one with the software and it didn't work either. I tried sending you a email but it says that I'm not aloud to so mrchgr@gmail.com. Thanks for you help
mrchgr
Medora,IL
Okay I feel like an idiot, I was plugging the cable into the earphone plug. I haven't messed with this in a long time so I guess I forgot but it works now that I plug the cable into the right hole. Thanks for the help.
