USB Sound Cards
Scannerfan15
dcr_inc
Not an EXPERT !!
Delta, Pa
I use them on one of my 4 feeds.. They work good but you may need to attenuate the input from the scanner to prevent distortion. Listen to the Harford County Maryland Fire, EMS and police feed on broadcastify.com if you want to hear one live. It is being fed from the line output jack on a HP-1 scanner
dcr_inc
Not an EXPERT !!
Delta, Pa
I was referring to the USB audio cards not the optical USB interface in the last post
USB sound cards are ok. I would pickup a handful of them cause they do tend to just stop working for no reason. You will need to shut off the mic input gain setting via the sound settings/recording properties. If you not running a feed I would just consider using r820t sdr for disc audio via SDR#
rtl2832u r820t SDR - YouTube
Scannerfan15
I have one and have terrible performance, everything's very weak.
http://forums.radioreference.com/software-defined-radio/261735-rtl-2832-help.html#post1926427
Can you give me some advise and tell me your setup.
n7lxi
Lancaster PA
I have several. They work fine.
Sent from my iPhone using Tapatalk. Sorry for any spelling errors.
My setup is here.
Mike Xeno: SHACK
Do you have the gain setup properly and what app are you using? sdrsharp or hdsdr also what antenna are you using on the 820t
