Use of MCD 5000 with CPI MR200(N) Tone Remote Adapter
wildwing
Lake Forest, CA
I am trying to connect up a CPI MR200N tone remote adapter to a Motorola MCD 5000 deskset and am seeing a rather strange issue which I hope someone here has encountered in the past: When the MR 200N is connected to the MCD 5000 through a Motorola Radio Gateway Unit (RGU), or, whether it’s connected directly (no RGU), I'm hearing a constant 2,600 Hz tone in the speaker of the MCD. When I connect the MR200N to a CPI TR10 tone remote deskset, either the tone disappears or I no longer hear it.
Note this 2600 Hz tone sits there persistently; before, during and after the low level guard tone gets sent.
Any ideas?
Thanks,
Kenan (Wildwing),
ramal121
Lots and lots of watts
Calif Whine Country
Well first off the MR200 does not run on standard TIA tones and MCD5000 will not run it. That adapter can only be used with its companion Alpha series remote. No clue where the tone is coming from.
ramal121
Calif Whine Country
Whoops. My mistake, I was thinking of the MCP200 series. Disregard the above post. Let me think about the funny tone.
wildwing
Lake Forest, CA
The issue has been resolved. Turned out to be a grounding issue. Due to the fact that the MCD 5000, and the RGU are powered by POE, there is no return path (no shield on the CAT 6). So, when the RGU's ground, the Radio's ground, and the radio's power supply ground were tied together, the went away.
Lesson learned.
Kenan (Wildwing).
