R7100 Used IC r-7100
merlin
DN32su
Any bad words about the Icom R-7100 ?
Got a fellow with one for sale and a low price. He knows nothing about it or if it works other than used.
TNX
Fast1eddie
Crafton Pennsylvania
A excellent receiver. Run it on a external power supply. The internal supply gets hot! I never had any problems with mine and wish I never sold it. R7100 was superceded by the R 8600, except the '86 does HF. All great receivers.
ratboy
Toledo,Ohio
Mine would do some very odd things when it got hot running on AC, like lose sync with my PC. Definitely run it on an external supply. I liked it, the only thing I had against it was it's slow scan speed (I ran it from a computer, it could only do about 22 channels a second, something like that). The receiver itself was about as good as anything I had to compare it to, including a friend's Yaesu FT-767 with the 2meter module in it, and another friend's ICOM 7000.
kruser
Well Known Member
W St Louis Cnty, MO
I think the R8500 was the successor to the R7100.
kruser
Well Known Member
W St Louis Cnty, MO
I guess that's why they are not scanners and are communications receivers. Many communications receivers today do have scanning functions but those functions are usually very basic and limited compared to an actual scanner.
With that, I also use communications receivers in scan mode myself regardless of the slow scan speed. I'm usually only checking a handful of frequencies or a small limit search that is not very wide between the lower and upper frequencies. So the slow scan speed does not really bother me much. If I find some active signals on an Icom receiver, I'll usually add them into a bank or favorites list on a Uniden or GRE providing the Uniden or GRE models even receive the signal.
I use an R7000, R8500, two R8600's and an R9000. All of them have great performance over a scanner for analog signals.
I do like the digital features the 8600 offers but it's a shame Icom won't budge on adding DMR into their receivers.
Who knows but maybe some day, Icom and others that still make communications receivers will actually support trunking systems and be able to follow them like a scanner!
teedee911
Longtime Member
Northern KY
I had two at one point, pretty cool units but as 'kruser' said, they're designed as receivers not scanners. I got tired of the clickity clackity relay noises when scanning and eventually sold both. Truth is, I'm a scanner guy but I had a blast with them.
