wikusm
Hi everyone, this is my first post here, I am a new HAM, I purchased a used Kenwood TK-80 HF transceiver from a guy over the weekend, he sent me videos of the radio working fine etc, now however once I got it home (and checking his videos) I noticed that no matter my power source, the radio will only transmit in Low power mode. The moment I switch to Mid, High or Max and key up, the radio cycles off/on again, first thought it might be an issue with the powered mic, so tried a morse key also, and does exactly the same. Took the radio to a fellow ham to check with his power supply and SWR meter in line, exact same issue. I am quite disappointed as this is my first HF radio, and now I don't even know where to start. The guy refuses to refund me, saying the radio worked 100%. Any tips on where to start? Just want to mention I had it running off a 13.6V 30A switch mode power supply, with an inverted V antenna and an auto antenna tuner. Really hope someone has come across a problem like this that could point me in the right direction
Thanks in advance.
73
ZS1WLM
73
ZS1WLM
