useing Kenwood NX-340u as scanner?
ve52001
Duncanville, TX
Yes I know I cannot program this NX-340u as a NXDN trunk. Can someone tell me if there aren't many channels at all on a small NXDN trunking system could I at least follow most of the traffic, if I program them as NXDN conventional? Wouldn't programming this radio be the same as trying to scan them on a Whistler TRX at this point seeing how the scanner cannot do NXDN trunking?
kayn1n32008
ØÆSØ
Sector 001
NXDN has a trunk status bit. You can not program the trunk frequencies conventionally and scan
The radio will not unmute
ve52001
Duncanville, TX
Ok, thanks for the reply. I was thinking of getting a TRX scanner but right now they are having issues with some NXDN systems, so I was curious about buying a two way instead. I'll just wait then and see how the scanners play out. Maybe even Uniden will release something.
