User blocked question.
gcopter1
Winter Park, Florida
I have an Icom ID-4100 and an OpenSpot3.
I am able to connect to the Brandmeister 3102, however, when I click on to any of my programmed TG's, I get a "User Blocked"message, what can I do to be able to use these TG's again?
gcopter1
Yeah, followed those as well. I can connect to the BM3102 server, I get a message saying I'm connected to a static TG. When I try to connect to another pre-programmed TG ,I get another message saying User Blocked.
SuperG900
WG5ENE
Edgewood, NM, USA DM65vb
So, you DID get and set your own personal hotspot password?
Some hotspots will connect using a default password, which is being phased out. It just happens that today is the last day that 3102 will allow those connections, and it's possible they are in the process now of removing that access.
Which talkgroups are you losing access to?
gcopter1
As a matter of fact, I did, twice, first, when it started acting up after it was working fine, then again about 20 minutes ago, just to be sure.
33015
3304
3305
3306
3307
3308
3309
33010
33011
33017
33033
90.
The ones starting with "33" are from Puerto Rico. I even tried "90", which I've got from someone in YT, I don't even know what that carries...
dmi
I heard someone mention this on DMR regarding static talk groups..
Have you tried deleting all static talk groups and then re-entering them?
Also, if you get user-blocked message, try connecting to a different MASTER server and then switching back to the one you were "blocked" from..
Jay
WA0CBW
Shawnee Kansas (Kansas City)
A system near me one time slot is static (can select only one local talk group) and the other time slot is dynamic (can select different talk groups).
gcopter1
Jay
Think I fixed it.
I re-watched a YT video. Turns out, at some point, the TG's I had stored in memory on my ID4100, had "TG" before the actual TG number.
I've since, removed "TG" and just left the number and so far, it seems to work.
