APX Users reporting low volume on APX 8500
pwo0123
Hello, I recently deployed about 100 APX 8500 radios with O5 heads. This was a replacement project from APX7500 with O5 head.
recently users have reported low volume coming from the 8500. During testing I noticed a slightly lower volume as well. I figured is was something to do with the “adaptive noise” features of the 8500. Users are reporting that they have to crank the volume knob to 85-90% to actually hear something. We use the standard Motorola Mobile speaker. Don’t have the part number but I can get it.
question is has anyone else noticed this? I’ve scanned both my 7500 code plug and 8500 code plug and haven't seen anything extremely different.
RFI-EMI-GUY
Ca
N you compare using an analog channel?
KE4SZT
Marion, SC
The latest firmware, R21.03.00, was supposed to fix that issue. It was a known issue and Mot had sent out a bulletin with the exact problem you are describing. The volume reduction issue was with units running firmware R20.61.00.
Tech21
Upgrade to the newest firmware.
One test you can do is add a conventional channel and test audio levels with a service monitor.
NVAGVUP
When looking at your codeplugs, switch to Expert View (View>Codeplug View). Then compare the TX and RX audio settings between 7500's and 8500's. (AGC, Gain, etc) It is possible prior programmer adjusted 7500's from default.
