USFS Proposes Jobs Pk repeater for HTNF
gvranchosbill
Douglas County,NV (4,859 Ft)
https://www.recordcourier.com/news/local/forest-service-proposes-jobs-peak-transmitter/
This article was in Record Courier local newspaper for Minden Gardnerville,Nv
Dated December 22 2017
Jobs Pk is 10,633 Feet and overlooks Toiyabe(HTNF R-4)and Lake Tahoe Basin(TMU R-5)
Bordered by Douglas County,NV Alpine County,CA El Dorado County,CA
Forest Service proposes Jobs Peak transmitter
December 22, 2017
Climbing Jobs Peak is a rite of passage for Carson Valley residents. If a U.S. Forest Service proposal is approved, those who've summited will also get to visit a new transmitter.
gvranchosbill
Residents oppose Jobs Peak transmitter proposal
Record Courier local newspaper Carson Valley,Nv
January 4, 2018
Negative on freqs due to a antenna problem at my location.
I give brief reason on forum:
https://forums.radioreference.com/n...3517-usfs-proposes-jobs-pk-repeater-htnf.html
California Radio Discussion Forum > Humboldt-Toiyabe NF Radio Frequencies
https://www.recordcourier.com/news/local/residents-oppose-jobs-peak-transmitter-proposal/
Carson Valley residents are protesting a U.S. Forest Service proposal to install a transmitter at the top of Jobs Peak.
On Thursday, Douglas Co Commissioner Steve Thaler said he'd written the Forest Service about the proposal.
"I have a concern that it will take away from one of the most iconic things we wake up to in Carson Valley,"
he said.The deadline for comments is 5 p.m. Monday, according to a letter circulated by the Forest Service to stakeholders.Thaler said he's climbed Jobs Peak eight times, and plans to climb it another eight now that he's got a new hip.
"I don't want to walk into an antenna," he said. "I believe there are other locations where it can go. I'm trying to rally the Carson Valley."
Thaler acknowledged that people probably won't be able to see the facility from Carson Valley.
Jobs Peak dominates the Carson Range as seen from most of Carson Valley.
In a letter to the U.S. Forest Service, Gardnerville resident Dave McNeil said he believed the transmitter would mar the scenery.
"I am adamantly opposed to the project because it will despoil treasured views of Jobs Peak and initiate the hideous intrusion of mankind's presence in an area that can easily be characterized as an untarnished, exceptional wilderness setting," he said in a letter to the Forest Service.
"Jobs Peak is easily the Carson Valley's most scenic natural landmark," he said.
The views of its impressive size, height and glacial sculpting are frequently photographed and painted, and enjoyed by residents and tourists alike; looking up at it from the valley floor and hiking trails located above Genoa, as well as looking down at it from surrounding peaks.
The tower and equipment would be a particular eyesore to the multitude of Jobs Peak climbers, Tahoe Rim Trail hikers, and other alpine recreationists who highly value the peak's pristine wilderness landscape."
The Forest Service is conducting an environmental analysis to erect a radio repeater on the landmark peak to improve radio communications.
According to a Dec. 7 letter to stakeholders, the repeater, shelter, solar panels and a 20-foot antenna would be helicoptered to the top of the mountain.
The shelter will be 5-feet square, according to the Forest Service.
Officials are calling the transmitter use minor, saying there is no circumstances warranting more analysis or documentation in an environmental analysis or an environmental impact statement.
Comments may be sent to elnoesser@fs.fed.us or by telephone by calling 760-873-2449.
silverspy
Portland,Oregon
Just a heads up to anyone interested. I copied some traffic on the HTF Carson RD Net this morning. I was in the other room, and really did not get the details,however, it sounded like they were getting ready to switch to the new frequencies for the Carson RD. Still unable to determine what the new frequencies are.
gvranchosbill
Can you say which frequencies you were listing to at the time you heard that traffic and i will listen.
I re read your post and the possible switch was anounced on 169.8750 correct?
Im going to start with HTF Bridgeport Ranger Dist freqs 170.5250 Rptr output 164.1875 Rptr input for starters it sounds like a likely choice.
The input tones are the same as they were for 169.8750 before they went to 170.5250 and i can confirm Lobbdell, Mean Pk 169.8750 are no longer in service/deactivated.
Lobbdell 146.2 input.
Mean Pk 156.7 input.
CSQ for output.
My random bad connection on my tram vhf high antenna stopped so im not going to take it down till later this year but im ready to listen again.
silverspy
Portland,Oregon
They are still definitely on 169.875, for now. Try also listening to 170.475 as an Output for the Carson RD. I’m back in the Region now for awhile, and I will listen up at the Northern to Central Part Of The Forest. Sounds like you are more at the Central/Southern end? Are you able to copy any traffic from Slide or McClellan from your location? I can only copy Slide, Peavine, Rawe and McClellan; fairly certain all of these are still on 169.875. Is there anyone else that is willing to give a report on Humboldt-Toiyabe ops in Southern or Central Nevada? Meanwhile, I will continue to listen from my position.
silverspy
Portland,Oregon
It makes the most sense to me, coming from a logical standpoint, that the new Carson RD Output will be 170.475; this is taking into consideration other frequencies used around the area, that would otherwise be available for Outputs, and the new NTIA high/low guidelines. I’m fairly certain that before the switch is made to a new frequency, some adjustments have to be made up at the sites, and then each Repeater is switched over one by one. This could result in some Repeaters temporarily being left on the old frequency and some Operating on the new. However, as an example: several years ago, the Arapaho-Roosevelt Net in Region 2, was changed from 169.875 to 170.475, and the Apache-Sitgreaves Net was changed from 169.875 to another frequency a couple years ago. Not saying that this is the case here, but maybe just food for thought.
