I am thinking about monitoring my car after a recent car break in with a small discrete FM transmitter ... aka a bug. The one I want has a vox circuit so that it only transmits when sound is detected by the microphone.
So, the needed range is about less than 100 feet, but it is a bit obstructed. I am also not sure if I will have to mount something outside / inside my car.
Wondering if anyone has used such a device and can advise on frequencies ?
I see the cheap ones use FM band frequencies (88-108 MHz) where as other (better ?) ones use other frequencies.
I just happen to have a Pro2005 scanner just waiting to be used for this. Or else a dual band Baofeng depending on the frequency used.
