BCD325P2/BCD996P2: Using BCD996P2 with Remote Head
carlopff
South Windsor, CT
Is there a way to connect my BCD996P2 with my remote head?
Unit has newer style connector on front of unit, either a new cable or an adapter....
KI4SXZ
Alexandria, VA
Uniden says it wont work with any p2 or hp scanners. But if your handy with wire making, you can always give it a shot and try. I use mine with my 996t, but wish it worked with my 536. Would make life so much nicer.
jonwienke
More Info Coming Soon!
VA
Short answer: NO. The wiring to the front panel display and controls is different.
N9JIG
Sheriff
Moderator
Far NW Valley
I built a cable to use the RH-96 with a 996XT thru the rear serial port and it worked fine.
I then tried it on my 996P2 and it did not work. I would love for this to work and would buy 3 more 996P2's if it did to replace the 996XT's in my truck.
tampabaynews
Keeping your PIO busy
Tampa, FL
The BCD996XT/RH-96 combo in my car is becoming useless due to Phase II. I'm seriously considering the Whistler WS1098 for my car.
