ka3jjz
Wiki Admin Emeritus
In another message, LouMagg wrote:
CSV file downloads are there for those people who want to bring that data down to their computers and manipulate it with spread sheet programs for their own use; it is not the method you use to import into your scanner unless you are writing your own software!
This statement is unfortunately only half true. While it's very true you can use a CSV file in a spreadsheet (or even in a word processor such as Word), there are some programs - such as Scan Control and many of the BuTel programs - that will allow you to import CSV data to build programming files.
How well the software does it is a matter of how the author(s) have decided the import is to be handeled. As I understand it, the Win9x programs need the data to be in a specific order before it will be recognized. On the other hand, Scan Control and I think BuTel's newer releases can handle the data in any order. You need to tell the software which column fits to which data in a process often referred to as 'mapping'. The now discontinued Radio Manager from Ben Saladino also had this capability.
I've reviewed a few of these programs (and the results are on the Strong Signals website) for Uniden scanners, and the quality of the import tends to vary widely. Importing from a standardized source such as the Web Interface is certainly preferable if available. But if not, a CSV import - if the software can handle it - is the next best choice.
This is not meant as a flame or an attack of any kind - it is meant to correct a misconception and set the record straight. Experience, as they say, is the best teacher.
73s Mike
73s Mike
