To OP: Yes
To donc13: Your response is very confusing - and not 100% accurate..... (GPS can be uses for BOTH departments and sites. So GPS is most
definitely useful to turn on/off trunkgroups, etc.
Best practice with a GPS (IMO - how I do it with very good success anyway....):
I have it set up so that my radios literally switch as I cross a state/county/city/reservation boundary. So, I only monitor the freqs/trunkgroups for where I am always physically at.
How?
Set up favorite lists by their
location. I personally set up separate FLs for entire counties that are smaller or in the boonies (not in the immediate metro area). For the metro, my FLs are set up by clusters of 2-3 cities/entities. Cities that are adjacent to one another go in a favorite, or for bigger cities, they have their own favorite list. With favorite lists set up for every city or "cluster" in the area. Also note that for irregular borders, you can set up multiple smaller rectangles to cover them quite accurately, using a mosaic like approach so to speak...
This approach requires that you take the time to define accurate rectangles (vs the default circles) for all of your department's location. There are multiple on-line tools that can assist you with this. Yea, it's some work, but once it is done, you have a 100% automatic way to drive and not even have to touch your radio.
bounding box - Google Search
https://bboxfinder.com/#44.735028,-93.598022,45.238152,-92.878418
(I just drew a random box around MSP. Use the tools on the left to draw whatever box you want and then use the lat/long for your GPS info you program. Remember it's always NW corner and SW corner lat/long of the box you are defining.
Note that because of how RF (radio waves) propagate, you always leave SITES as circles. These rectangles/bounding boxes are only for your departments.
Note #2: Also, range should be briefly discussed. In your PROFILE, there is a global setting for range. This is NOT the same as the circles (or rectangles) set for any departments or sites. Maybe a real world example will help. I have my range set to 0. This then sets things up so that my radio switches exactly when I cross a programmed box's border. If had it set to 1, it's switch a mile before the boundary, 2, would be 2 miles before crossing, etc, etc...
