What are the rules when using an auto patch to dial 9/11?
Emergency Autopatch - 911 Access
Key-up, and enter the emergency number ( 911 ). Un-key, and the voice will read back “Centre County Emergency 911 access” after which the repeater will dial the number. You may also dial ( 2 * 911 ).
Other Emergency Autopatch Numbers
The 85 repeater can dial the following emergency services by entering the 900 series codes as listed. Simply key in the three-digit number to access these services
910 – Huntingdon County Emergency Dispatch Center
911 – Centre County 911 Emergency Dispatch Center
912 – Pennsylvania State Police, Rockview Division
913 - Centre County Non-Emergency police assistance
914 – Penn State Campus Police
My friend just bought an Android phone for under $50. He can call 911 anywhere from that phone, even if he isn't signed up with a cellular service provider.
Maybe it's that way in Kansas; here in southeast Virginia the public safety dispatchers know it's semi duplex the moment we say "calling via amateur radio". Of course, the other indication is silence followed by a microphone opening.And when the dispatcher doesn't realize it's a semi duplex system and talks continuously you will eventually give up and die.
I would just like to note that if you are in an emergency, all normal operating procedures are suspended if you or someone else's life is in danger. I mean unless you are just calling 911 to report a buglary or something (non-life threatening) then you don't really need to worry about rules.
