TickingMind
- Joined
- May 20, 2021
- Messages
- 2
Hello all
I've been using a VHF quarter wave antenna to monitor weather and a local business that I run at 156 MHz and have found that the third harmonic of the vhf is about 465 MHz which is around the GMRS band. I'm stuck using the quarter wave because I need the high vertical beamwidth to get to the upper areas of the mountains that are around me. Should I wish to also monitor GMRS for jobsites would the same vertical beamwidth apply or is there a different formula or method of determining this?
Your thoughts are much appreciated!
TM
TM
