Using KPG 101D software with TK-2170
lstewartff
I obtained a copy of this software to program our radios. I am having a problem with getting the radios to ID with the PTT button. Could someone explain the best way to do this. also is there a way to make the radio ID without giving the tone when the PTT button is pressed. Any other programming info is helpful or if anyone knows of a tutorial for this software to help with what we haven't already figured out.
sfd119
Set it as Post PTT and not pre. Otherwise, you can turn the "beep" off but you still need to wait before you talk.
lstewartff
Yes I am setting up Fleetsync. I have set all the radio Fleet IDs as 100 and then gave each radio an Own ID. in the ID List I have set the Fleet to ALL, the ID I have put each radio number in, then in the ID Name I have put each call number. I had it ID as the call numbers but now it is only showing the seven digit radio ID.
I do have it set on "Begin On Transmit" with the beep turned off.
Thanks guys for any help
In fleetsync menu is the caller id display box checked?
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
sfd119
Let's get Fleetsync working first before you go out and get all fancy with Caller IDs.
I'm doing this from memory so I may be off a bit.
In the Edit Menu, there should be a Fleetsync option. Go into there and enable it.
Then, go to the Channel Edit and under PTT ID (Analog), change it to EOT. That should enable Fleetsync on the channel in question.
In his third post he said it was working, it just wasn't bringing up the alias.
lstewartff
Ok, I have I working sort of. I have some radios that will ID when receiving, but when they transmit they ID on another radio with the 7 digit ID. I have looked thru all the settings in both programs and can not find the difference that is causing this. I there something that needs to be checked that causes a radio to send the ID signal or receive the right ID. I hope this was clear enough its a lot harder to explain than I thought.
sfd119
Is this analog or digital? If it's Digital it's the P25 ID.
If it's analog, then you need to add that number to the Alias list in Fleetsync.
