Using lmr400
Colton25
So i'm trying to receive a VHF frequency that's about 40 miles away, right now i have an antenna that's about 40 feet tall with a yagi pointing in that direction. My cable is rg-6u with a run around 80 feet, my reception right now isn't very good at all almost unreadable. My question is if i replace my rg-6u with lmr400 does anyone think my reception will be fixed? Is it worth the money?
n5ims
Using a coax loss calculator (something that everyone with questions like yours should have) I come up with the following values:
RG-6 loss @ 160 MHz for 80' of coax - 2.864 dB
LMR-400 loss using the same factors - 1.255 dB
Link to what I used so you can play around to find the best solution for you. Coax Calculator
Since lower loss is generally better, changing the feed to LMR-400 may help. Will the 1.6 dB matter? Who knows, it may and it may not. That's not a great deal but could be enough to matter.
There are several other things that may be going on. All could be causing your problem but there's no guarantee than any of them are.
1. Is your antenna pointed in the right direction? A yagi is very directional so being off even a few degrees may be the difference between a fully quiet signal and one that's very noisy. Try rotating it to see if you can get better signal strength. Remember that just because the agency is in one direction, their transmitter may not be there, especially if there are mountains in the area.
2. Do you have any large obstructions (tall buildings, hills, mountains, etc.) between you and what you want to listen to? They could be blocking the signal.
3. Do you have strong stations nearby or in line with your antenna's main lobe? They could be overloading your receiver and causing it to become "deaf". It could be powerful paging transmitters, NOAA Weather Radio transmitters, FM or TV broadcast stations or even some 2 way radio transmitters.
4. Is your current coax in good condition? It could be damaged by water, which will ruin its ability to pass signals well. It may be due to improperly installed (or incorrect types) of connectors, connections not sealed against water, cracks or other breaks in the coax's outer plastic covering, etc.
5. Is your antenna designed to work on the frequency range you're trying to pick up? One designed for UHF may not work well on VHF for example.
KevinC
Other
Super Moderator
Home
To add to the above, I'd bet you have a GRE-based scanner...correct?
Colton25
First of all thanks for the fast response. As far as pointing it in the exact direction i never thought that that could make such a difference, i will try that first. I don't have any major obstructions, i can almost bet my coax isn't in good shape, i remember having to use a adapter at the antenna side of the cable and i know it's not completely water proof. If i buy the 400 i'm going to make sure it has the correct connectors so i can eliminate the adapter. Do you have any good recomendations for waterproofing at the connection? When your talking transmitter do you mean the repeater or something else? Because i know i'm not pointed at the repeater.
Something i didn't mention originally is i know someone who is further away from the station that is receiving a good signal on this frequency so i know it's possible.
