I got a BC350 scanner in my truck I use mostly for scanning the local police chatter. I had a cheap walmart cb antenna on the scanner with a bnc adapter and it worked greater for vhf low. But recently U bought a radio shack scanner antenna hoping it would work better than my $10 walmart cb antenna, but i cant seem to get the vhf low chatter on about the 150 mhz band, even when im only a couple miles down the road from the police station it still comes in bad. So I was wondering if I used a t-connector and used both antennas at the same time if that would get good reception in both high and low frequencies. I know with a cb you can use 2 antennas for vertical and horizontal transmitting and stuff but i just wanted to make sure this is safe for the scanner to be using 2 different kinds of antennas at the same time.
thanks
thanks
