Using my EX600 XLS as a pager
tkaplan501
Croton-On-Hudson, NY
I have a Moto EX600 XLS portable radio, and I know you can use it as a pager.
I have programed the tone frequencies and the sequence (A-B) in a Quick Call II system already. I have also assigned that signal to a channel I designated as my pager channel (The dispatch channel). I did a test by setting the signal to a test frequency, and using another radio, I toned out on this test frequency. Now the EX600 did go into call alert, and made the proper beep, just as if it were a pager. So it worked. Now my problem is that the pager channel is constantly open on the frequency, monitoring everything. What I want is to actually use it as a pager where it will only open up on the desired channel when the tones go out (Like a monitor v). I do not want to scan my dispatch channel while on this pager channel, because the county dispatches my fire/ems, along with like 20 other departments, and I only want it to open up, and monitor the frequency when MY tones go off...
Is this possible? Please let me know if I am not making sense, I will try and clarify.
RKG
Not familiar with the EX600 in particular, but somewhere in the MDC "System" programming is an option for 'AND" or "OR" audio gating. Your radio is set for "OR", which means it unmutes with either proper PL or proper MDC. You want to set it for "AND", which means radio requires both proper PL and proper MDC.
Also, you may need to switch from the "Page" function to the "SelCall" function.
SteveC0625
Northville, NY (Fulton County)
The EX600 is part of the Pro Series if I am not mistaken. This little info file should solve most of your problem:
https://drive.google.com/file/d/0BxAVX2o_3yDlU0NFd3RaMEl6R2M/edit?usp=sharing
I grabbed the info from a couple of forums over the years and polished up. You should be all set.
SteveC0625
AND/OR is selected in the individual personality on the Signaling tab.
The SelCall function for this purpose is in the Signaling section under the Quik-Call II System which is what Tommy is using, not MDC.
The file I linked in the previous post contains specific instructions for setting up Quik-Call II on this series of radios.
tkaplan501
Steve, thank you so much!!! You know everything!!! I also figured out my MDC issue from the other day, and now this works... Question though... Is there a way I can change the sound of the alert... Any alert that sounds like a pager going off?
Also, will the QCII work, and will it go into call alert if the channel is CSQ with no T/DPL code?
SteveC0625
Tommy,
I am not familiar with a way to change the alert tone when a call alert is received. Doesn't mean it is not possible, just that I've not encountered any discussion on that in over two years of roaming the net seeking info on the Pro Series of radios. If someone knows, I'd be delighted to learn about it.
I usually don't set TPL or DPL on personalities set up for QC-II decoding/alerting. CSQ works fine. Since you are not monitoring the channel, really no need for any PL. The channel is silent until an alert is received. If you're going to respond, you'd switch to the Tx/Rx version of the channel anyway where the proper PL's would be set. At least that's how I'd work it for my squad.
tkaplan501
Tommy,
I found it in the Signaling Configuration menu. There are 7 different alert tones, also a standard one that you can choose from. Alert 1 is the most like the Minitor V Pager... FYI. Also, you were right about tones for the channels, so I just put the pager channels in CSQ.
SteveC0625
Thanks! I will add that info to my notes.
tkaplan501
Does anyone know if there is a way that it could alert and open up when my tones go, and then broadcast the channel? All it is doing right now is beep when my tones go off.
