Using ProScan to program a BC125AT
ih784
I'd like to use the RR database to program my 125AT are SCAN125 and ARC125 (or Uniden) my only options or can I use ProScan? I have used ProScan for my SDS100 and have a 125At on the way.
Enjoi19
The BC125AT is listed as supported by ProScan
ProScan supports the BC125AT, BC250D, BC296D, BC346XT, BC346XTC, BC780XLT, BC785D, BC796D, BCD160DN, BCD260DN, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BCD996P2, BCD996T, BCD996XT, BCT15, BCT15X, BR330T, SDS100, SDS100E, SDS200, SDS200E, UBC125XLT, UBC126AT, UBCD3600XLT, UBCD436PT, UBCD536PT, & USDS100 scanners.
ProScan
Software Provider
Ontario, Calif.
I’d rather use proscan and will not buy anything else if it will work with the 125 the same way it does the sds100 and, I guess it will.
It works basically the same with some differences as you may know. The SDS100 database is accessed using the 'Favorites Editor' menu. The 125 database is accessed using the 'Database Editor' menu. Also the SDS100 is a DMA type and the 125 is a bank type.
Use a different folder for the instance running the 125 so the config and logging files don't get mixed up.
Scan125
UK
Well I'll chip in here and say:
1) PROScan is very well respected and supported
2) My Scan125 also has the credentials of PROScan but it does not support Radio Reference data import with their subscription accounts
3) Others
I think you need to look at ALL programs and decide what you want to do (e.g. programming, full PC control, logging etc. etc.)
Try both PROScan and Scan125. NOTE! If you think you will have more than one scanner then PROScan would be your better choice as Scan125 is dedicated to the Uniden 125/126 series of scanners.
Falcon9h
Just my experience but I like the ARC products. I had gotten it for my 125 and followed suit with my other radios because I had already learned the software, so little learning curve.
