Using RR Database feature in UniTrunker
FuelForFire
The Garden State
I have been using Unitrunker for a while now and I have not been able to get the RR database feature to work.
These are the instructions posted:
rfmobile said:
It's under the system finder ...
From the main menu, type "F" for [F]ind; type "S" for ystem; press TAB key once; select type of system (eg. "Motorola"), press TAB key; type in the system ID; press TAB key; next to "RR DB User Id" - type your user id; press TAB again; and type your password.
If all looks correct, press "F8" and wait a few seconds.
Limitations:
You must of course be online for this to work. It may not work with some web proxies. This really only works for Motorola systems. Lindsay likes using "Site 1" for non-networked systems (like Type I and Smartnet) so RR DB channels are not downloaded properly - but talkgroups should come through just fine.
-rick
However, when I enter in the sysid and type those are the only two options available. There is no fields for RR user or password.
What am I missing?
Mike
