Using same laptop for hp-1 and bcd536hp scanners?
dmack550
South bend, Indiana
Can I use two different versions of sentinel on one laptop for my two scanners?? Already Installed sentinel for the hp-1...need to install for the bcd536hp. Will they work and be recognized by each scanner when they are hooked up to the laptop?? Thanks for any help!!
N9JIG
Sheriff
Moderator
Far NW Valley
Sure, I run both versions for mine all the time.
I would not have both radios connected at the same time lest you choose the wrong one by mistake.
marksmith
Anne Arundel County, MD
There is no problem at all. Each piece of software only recognizes the radio it is supposed to see and work with. I use both regularly.
WS1095/536/436/996P2/HP1e/HP2e/996XT/325P2/396XT/PRO668/PSR800/PRO652
Voyager
The SW won't write the 'wrong one'. It will simply respond with an error.
