Wasn't sure whether to post these questions in this thread or the streaming thread, but I have been using SDRTrunk to scan multiple systems on and off for some time now. I'm pretty familiar with how to program works but I have some questions before I want to run about 5-6 feeds.
1. Can the program support running about 5-6 broadcastify feeds using alpha tags over two systems? I'm currently using two SDR's to get enough spread.
2. If multiple TGs are talking that I want on the feeds, will they talk over each other on one particular feed? ex Feed 1 has Tac 1 and Tac 2 in the list. Will both talk over the feed at the same time or will it be one or the other (just like a normal scanner)?
3. Will the program stream different TGs over different feeds at the same time? ex Feed 1 is fire department and Feed 2 is law enforcement coming off the same system. If both Fire Dispatch and LEO Dispatch are active at the same time will both TGs go over their respected feeds at the same time?
Thank you for your help, I'm still new to all the SDR stuff
