Using SDS 200 as a feed
NA3E
Webster, NY
I have recently upgraded to a SDS200 for my feed. While setting up the feed, it says to use the mic output on the rear of the scanner. The SDS200 does not have a mic output on the rear of the scanner, just ext spkr jack. A friend said that if I used the mic output jack (that doesn't exist), I would not be getting the constant hiss on my feed. Using a PC with the audio hosed into the mic input.
Any suggestions to making the feed sound better.
fxdscon
¯\_(ツ)_/¯
Use the RJ45 connection on the front of the SDS200 for audio through your LAN/internet. Far superior audio than other connections.
jonwienke
More Info Coming Soon!
VA
Seconded. Running a speaker output to any audio input is a really bad idea. Using the network port also eliminates the ground loop issue.
ProScan
Software Provider
Ontario, Calif.
I agree with everyone. Using the LAN/Ethernet port produces the highest quality audio.
