NA3E
I have recently upgraded to a SDS200 for my feed. While setting up the feed, it says to use the mic output on the rear of the scanner. The SDS200 does not have a mic output on the rear of the scanner, just ext spkr jack. A friend said that if I used the mic output jack (that doesn't exist), I would not be getting the constant hiss on my feed. Using a PC with the audio hosed into the mic input.
Any suggestions to making the feed sound better.
