vince157
Hello fellow scanner & radio enthusiasts! Allow me to introduce myself, I'm Vince and I'm in the 23703 zip code of Portsmouth VA.
I'm 64 years old and have been a fan scanner listening since the days when I had to purchase crystals from my local radio supply store in Olde Towne for my Radio Shack desktop scanner. Circa 1971 maybe? Since then I've owned several scanners and enjoyed them immensely. Recently as you know PPD went digital and I finally bit the bullet and purchased a Uniden BCD325P2 scanner to use.
Where I stand right now? I programmed my scanner using the frequencies listed on the RR web site, starts with 856.xxxx and goes up from there, about 8 total maybe? After looking at some of the posts here I feel I may be missing out on a lot listening in on transmissions.
So in order to acquire more frequencies I purchased a Uniden BC-SGPS serial GPS receiver kit, new open box for a mere $40 on ebay. Well, I hooked up all modules per the instructions and when I inserted the the 12v accessory plug into the car my scanner read 'illegal voltage' hmmm. Didn't harm the scanner, whew!
Fast forward to the 352P2 spec sheet, DC5v +/-
Uniden states that this box of stuff is compatible with the 325P2 scanner but I can't see how if the input voltages are so different. Have any of you used this kit?
I can see it working on a scanner with a 120v input but I'm flummoxed as to why it can't work on the 325P2 scanner.
Let me add that there is a video on youtube where the gentleman is using this kit with a SD100 and a 325P2 sitting beside him but he never showed it connected to the 325P2 scanner. I guess that's why comments are turned off for that video
Your thoughts and input would be appreciated!
