Using two usb-1 cables?
Puyallup,Pierce County, Wa.
Is it possible to use two USB-1 cables at the same time? Or would there be a problem with the Driver? I have a BR330t and a BCD396t and would like to run two different software programs at the same time. I've got Vista.
iMONITOR
MACOMB, MI.
I haven't actually done it, but in theory it should work. The driver should assign different COM ports to each.
Mark01
S.E. Michigan
I've used ARC330 & ARC396 Pro simultaneously to run my 330 and 396 on windows Xp with no problems ,as mentioned make sure you have different com ports assigned for each program.
