keithmj
- Joined
- Dec 19, 2002
- Messages
- 304
- Reaction score
- 2
Using Win500 to program the PRO-197 and downloaded everything from the Radioreference datebase for Pinellas County, Florida. I had a few questions. The Frequencies are in the system frequencies section as they should. Underneath that is the Trunking Tables button, there is a Band selection section and I selected the 800MHz Standard and it has 5 frequencies as the base frequencies. The five base frequencies are completely different than the system frequencies. Why are the system frequencies different than the Trunking Tables frequencies and how do I know what the frequencies in the Trunking Tables are suppose to be since frequencies change? And I can't find these frequencies on Radioreference so I don't know if they are correct or not?
Another question..Also I initalized the radio to the default settings by tuning on the radio then pushing the zero button then the one button then ENT button. Then I downloaded the frequencies for Pinellas County, Florida and the talkgroup IDs into the scanner using scanlist 1 so I only have one system in the radio for testing purposes. The radio scans and works as it is suppose to but the scanner keeps stopping or hanging on the frequency 862.837500 and I don't even have this frequeny programmed into the radio and I have to use the FUNC and L/OUT feature to get it scanning again. Where is this frequency coming from since it is not in the system frequencie section or the trunking tables section?
Thanks..Keith
Thanks..Keith
