Utility to Help Identify/Decode Random Digital Traffic??
aka_ramon
There's a system near me on the VHF high band, non-trunked, that has P25 audio and some sort of digital data (that I understand is UDP/IP encapsulated).
I don't know the data speed (2800, 3600, 4800, or 9600) or even the modulation type (well, I know my 396t can receive the P25 audio, so that limits the modulation type to C4FM or CQPSK, I guess).
I'm wondering if there's a utility (1) that'll help me figure out the unknowns about this system, and (2) dump the IMBE and/or IP data packets in binary and/or hex?
Always trying to learn... TIA,
R
I'm wondering how you know that.
I have not seen a program that does this. There's a couple of programs out there to dump the control channel packets to a file but not the voice packets or data packets. The effective throughput for confirmed data on a P25 channel is considerably less than 9600 bps.
-rick
aka_ramon
Thanks for the reply, Rick.
I assume you mean the "UDP/IP encapsulated" part of that sentence? :)
Well, you know... You read, you google, you read some more, you google some more...
rfmobile said:
I have not seen a program that does this. There's a couple of programs out there to dump the control channel packets to a file...
Interesting. I couldn't find anything either... heavy sigh... which surprised me.
Got any pointers on where I could or should start? I s'pose I should hook up a discriminator tap to one of my old analog scanners. Do any of the existing decoding programs have source available (yeah, I can code)? I can't imagine writing the fundamental input functions would be particularly "fun" so I wouldn't mind avoiding that part of the mess if at all possible.
Is there a better place to post these sorts of questions?
Thanks again,
R
First, please realize the territory you're getting into here. Do some digging on a program called MDTMon along with some of the potential issues with federal and state criminal code. I'm not saying it's illegal but it has been problematic for some - depending upon situation (like juristiction).
Yes. Also, though not required but hardware that supports 96k samples per second are preferred (as opposed to the standard CD audio quality 44.1 k samples per second). Don't bother with a slicer - at least not for this application.
There's at least one program in beta that will have source available once the program is officially released. The code is under a GPL license.
Probably not but you may want to try the GNU-Radio mailing list. There is additional GPL'd code there that may provide inspiration. Another GPL'd project is the SDR1000 but I can't suggest the SDR1000 because it is designed for HF ... it won't work above 60 Mhz or so.
-rick
