VE1GAT
Secular Humanist, goodness without godness
UV5RE+
firmware N5R-213
chirp-daily 20150814
Problem:
radio is set to dual watch with no priority.
radio set to slot A and receives RX on slot B
radio then flips back to slot A to TX.
Same happens if B slot is selected and picks up RX on slot A, it reverts to slot B to TX.
Yes dual watch still works, but this bug/coding causes TX problems.
Person one has radio set to the following
A 154.6 Mhz
B 446 Mhz
TDR is on
A is active
Person two has radio set to
A 146.52
B 446
TDR is on
B is active
Person 2 uses slot B to call 1.
Person 1 hears 2 on slot B. ok
Person 1 responds to call but radio switches to slot A (its starting position)
Person 2 can not hear person 1 because of freq differences.
I posted this to CHiRP mail list and Jim reported back it is an unfixable issue with this firmware, seems to be the newer firmware.
How many more firmware versions have this error?
I'd avoid radios with those firmware versions
firmware N5R-213
Problem:
A 154.6 Mhz
B 446 Mhz
TDR is on
A is active
A 146.52
B 446
TDR is on
B is active
