UV-B5: Reprogram unused button?
popnokick
Northeast PA
The Baofeng UV-B5 has (as far as I can tell from the manual) an unused button directly below the "Monitor" button ("E" in the manual illustration). The attached diagram shows the location (orange arrow). Is there any way to program this button to perform any function on the radio? Specifically, I'm interested in a "Reverse" function that would cause the radio to switch to the offset (TX) frequency and open the "Monitor" function. The existing Monitor ("E") button merely opens the squelch and on the receive freq, regardless of whether there is a transmit offset. The purpose for adding a "Reverse" function to the unused button is of course to listen to a repeater's input frequency to determine if a station is within "direct" receiving range. I checked the UV-B5 PC software and CHIRP and did not find a way to do this (hoping I missed something).
jk77
Ohio
I don't think so. There is a mod floating around where you can make the unused button into a switch for the LCD backlight, but that is all I've heard of. It can't really be software programmed unless things have changed since I bought mine a few months ago.
KC9HI
Setting menu 25 (REV) to ON with swap the RX and TX frequencies or the currently selected channel.
Jim KC9HI
