UV5r img files
flashmang1
I have found through some painstaking trial and error that even though the new CHIRP software will not allow you to fully load img files if the firmware doesn't match, the older chirp does and that is where my problem started between BFS313 and NFR-20. But now I run into the same problem with BFS311 firmware. I have fixed the problem with the first two revisions by making sure I have the correct revision in the img, but if anyonw has the default img file for BFS311 I would greatly appreciate it.
KC9HI
Visit the miklor.com website. Got to the UV-5R area and look for "Recovery from Erratic Behavior". There is a link to my collection of CHIRP .img files which includes one for the BFS311. To recover from a cross-loaded N5R-20 .img file, the BFS313 should work, too.
Jim KC9HI
