UV5RV2+ Programming Lock
drayd48
I have a few baofengs myself but I am now programming them for some use at a business. I had programmed some frequencies for them using Chirp into the Channel Memory Mode and everything worked fine. Well, a few employees started messing with the radio, and bumped buttons and clear some channels out, and reset the programming. Is there a way that the radios programming can be locked by Chirp and the radio not allowed to be reset by the keypad? Thanks
Update - I am very aware of the keypad lock
nd5y
Wichita Falls, TX
In Chirp go to the Settings/Advanced Settings tab and disable (uncheck) RESET Menu and All Menus. If I remember right that only works if you keep the radio in memory mode.
