Hello all. Well when I first purchased my pro 197 I did not save what was already loaded on the radio. So all my V Folders were deleted. I did locate and got on the 20 files back on my hard drive in my pc. Now when I upload a V file then upload another V Folder it will overwrite the first file I unloaded. So my question is: how can I upload all the V FILES (1-20) at one time. So that way I will have all the V files again as it was orginially as when I first purchased the radio. Thanks..
Win500's "Virtual Scanner Management" tool will allow you to upload 1 V scanner folder at a time. If you select successive numbered V scanner locations each time you upload a folder, they will not be overwritten. The only way you can overwrite a V scanner folder is to upload another one to the same location again.
It will also let you upload all of them at once.
Not sure why you would want the factory folders taking up space in your scanner anyway, they are very, very much out of date, and of little use.
