V-Folders
SirTom
Rochester NY
Came back to scanning after 20 years. I have a Pro-106 and the 20 V-folders are empty. How do I put in the factory loaded info back into these 20 folders? Seems Radio Shack doesn't have the answers. No support on their website either. Thanks for any help.
dougjgray
Englewood CO
I know of 2 ways:
1) use win500 virtual scanner you can also get the factory V-Scanner data from starsoft I have never used it but there are instructions in the win500 folder
2) load each V folder into scanner memory 1 by then save to the appropriate location
JoeyC
Senior Member
San Diego, CA
Are you planning to put this radio up for sale? Otherwise, what is the purpose of putting in a bunch of V-Folders in for areas that your scanner cannot receive?
SirTom
Rochester NY
V-Scanner
I used Win500 with confusion. I purchased ScanControl Pro V7.1.0 from ScannerSoft and found I can use it without reading the instructions! It has a cool battery level indicator in the software panel. It's a bit expensive but it did what I wanted to do and it was easy to use.
SirTom
Rochester NY
V-Scanner
I'm new to digital scanners. It's for practice. The scanner was empty when I received it. it's not for sale, it's a beauty!
