Thanks Mike, I do have Win500. A friend on mine sent me a Win500 file of one of our counties near by and I was just trying to get that file in the v-scanner file. When I do get it in there and I go to that county does it load into the scanner what I have in there now or does it just come out of the V-scanner? Hope that made sense...Thanks again
There are two areas of memory used in the Pro-106/197.
The first are is Working Memory. This is the area of memory the scanner actively uses to monitor radio activity. Working memory can contain up to 1852 objects (depending on the types of objects stored, this number may be less). This is what you are listening to when the scanner is operating.
The second area is V-Scanner memory. This is just a simple fileing cabinet to store copies of working memory in. V-Scanners are not actively scanned by the radio until they are loaded into working memory.
If this win500 file you're trying to use is for your local area, use the upload to scanner option (as opposed to the v-scanner option) to load that information into working memory. You might want to save whatever you have loaded into the radio before doing that though.
Mike
