V-scanners
DoggDriver
hello forum, I recently purchased the software for Pro-96. I've downloaded the software but can't seem to be able to listen to the V-scanner banks. please tell me how to bring up the V-scanner banks for listening. the only way I'm able to listen to them is when I load them in main memory. I want to thank you in advance for any help I get with this.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Think of the main memory as the scanner and each folder in V-Scanner as a separate p96 file which needs to be loaded into the main memory to listen to. Each have 10 new banks of data. Since you have Win96, you always have a file of your current main memory so you won't lose it. But, if you store (send) this file to the scratchpad, folder (.), then you have it available to reload any time you bring a folder from V-Scanner.
Dubbin
Findlay Ohio
Wow I know how it works and that even confused me :wink: Try it in newbie terms :lol:
UPMan
In Memoriam
Arlington, TX
V-folders are just places to save different scanner configurations. You can only scan what is in main memory. To scan the contents of a particular v-folder, move it into main memory.
fmon
Eclipse, Virginia
Dubbin said:
Wow I know how it works and that even confused me, Try it in newbie terms
His own statement above indicates he doesn't need baby talk...do you. :wink:
DoggDriver
thanks fellows I have a better understanding. I'm learning everyday. thanks alot for the feedback.
