Anyone else with QCII problems on conventional analog?
V1.3 generally is working great. BT and intermittent connections in the amp charger seem to be greatly improved. The separate P25 trunking priority scan list is a nice feature!
However, I use my G5 predominantly in QCII pager mode. I have major problems. While not mission critical for me, as this is an emergency alerting pager I am concerned if this is happening to the primary target group users.
I am still gathering information but the problems are as follows:
1. In the amp charger, the setting of alert duration to "tone B" length is disregarded; the audible alert tone continues to recycle indefinitely and the message does not record, resulting in missed calls. (This may occur only on first page following reprogramming; my pager has always missed the first page following programming.)
2. Again in the amp charger, the post transmission audio does not squelch until the unit is removed from the amp charger, despite having audio squelch setting on "low" and CTCSS enabled.
3. Timeout reset no longer seems to work. I noted there are reports of timer issues in other reports, so this may be related.
I have 6 page channel knob positions in a Silent Scan list. All channels are discrete VHF analog with only one tone pair per channel, so call stacking is not an issue. In V1.2 this worked flawlessly whether in or out of the amp charger. The G5 scans the channels, alerts on QCII, records the message, and times out after the set 60 second timeout reset. If a second page occurs within 60 seconds, it stops the first recording session and begins a new one. In between the transmissions the receiver properly squelches. The only exception is that for the NWR channel I need to manually reset since the carrier never drops.
I have insufficient data to determine if these issues are as pronounced outside the amp charger.
As much as I appreciate the new features, for my primary use I may need to find the V1.2 firmware and downgrade to restore expected functionality.
