Firmware Version: V1.31
PPS Version: V03.16.21
Device software (V1.31) and programming software (V03.16.21) includes numerous bug fixes to
correct issues and optimize performance. An overview of the changes included in this release are outlined
below.
Bug/Issue Fixes:
• Fixed problems with conventional VHF QCII alerting
• Fixed issue causing P25C QCII Stacked Paging Decode Failure
• Fixed issue where TGID hold timer would only count down when the pager screen is active
• Fixed issue that caused pager to crash when changing knob positions in some zones
• Fixed issue where pager would not connect to PPS while screen off & would not charge until the screen turned on
• Fixed issue where pager would randomly reset when programmed with a large programming file
• Fixed issue in PPS that caused software to shut down when attempting to write a profile to pager
• Fixed issue when a P25 TG is received, and voice transmission is over, the squelch that opened speaker kept speaker
on with a hissing sound
• Fixed issue causing pager to lock up while navigating the settings menu
• Fixed lost audio issues, where received message audio would not play through speaker and recorded messages
would not play back
• Fixed issue of pager receiving messages while powered off and charging (Green LED flashes and screen lights up
showing "charging full")
• Fixed issue where pager decoded while powered off in the Amp Charger
• Fixed issue where during off duty state the voice record would continue for 10 minutes
• Fixed issue when 2-tone is sent from P25 Conventional channel on console, after tones end during hang time a
different TGID and ID is seen on the screen and the pager reset
• Various other under the hood fixes and improvements to optimize performance
PPS Changes/ Feature Modifications:
• Added “Factory Setting” function that allows user to reset pager to original factory settings
• Added new Radio Reference import process (for Radio Reference premium members)
Is there a link to what 1.31 does vs 1.3 and what’s the fixes are ?
