VBCPS Hytera DMR System
kainixon2187
Virginia Beach, Virginia
All Virginia Beach schools have switched over to Hytera DMR, using BD552i's. The analog channels are still programmed in as backup. Channel 1 is used for admin, security, custodians in and channel 2 is for cafeteria staff (not used a lot) in elementary/middle schools. Channel 1 is used for admin and security and channel 2 is for custodians in high schools (both pretty active). I have the contact list. If two schools are right next to each other they move to the next color code down. If there's a cluster of them together they switch the frequency entirely.
All Configurations:
Default Configuration for ES/MS:
Default Configuration for HS:
I was also picking up Alanton ES with a color code of 0? At first I thought it was because I was out of range but even driving past it still a color code of 0.
  • VBCPS_HyteraDMR_ContactList_20200513 - VBCPS_School_Facilities.pdf
kainixon2187
idk whats the deal with color code 0. I think its a valid color code but I'm not 100% sure, it just doesn't match the color code scheme for the city. could it be decoding color code 1 instead? because first colonial is on color code 8 and cox is on color code 7 so it cant be on either one of those. I'm using a tyt mduv380
