RFI-EMI-GUY
- Joined
- Dec 22, 2013
- Messages
- 6,968
I know this thread is a little old, but I know exactly what this guy has because I have several of them myself. The were surplused from PA State Police. It is a VHF Syntor X9000 with a box that mounts under the drawer unit. Inside this box is the Y1082A. It has 2 antenna connectors, one labeled radio and the other antenna. There is a data connector that piggybacks on the drawer unit main block.
Inside it is a VHF crystal controlled receiver (YLD1003A) that looks part Mitrek. It has a HLD4052A pre-amp. There is a Motorola RDD4684A six can duplexer, and 2 antenna relays.
Think of the old Flexar repeater and you will grasp the concept.
In normal operation of the mobile unit, the RF relays would by-pass the Y1082A.
There is a repeater button on the Syntor control head that I imagine would energize the RF relays inside the Y1082A so a received signal would get routed to the external receiver.
The frequency the PASP used was 154.755 simplex. A handheld would transmit on 159.21 (PL 186.2) and the Syntor would repeat it on 154.755. The handheld would receive replies on 154.755.
Everyone is correct here that the Syntor itself is useless for commercial operation anymore, and the 150-174 split doesn't tune well to ham IIRC, and you have the hack the RSS to program the frequencies out of band.
Here is someone selling or inquiring about the same thing (pictures)
สà¸*บถามà¸*ุปà¸à¸£à¸“์ Motorola Model:Y1082A
Personally I'm interested in any information on the duplexers - anyone?
Very interesting device. It looks like that "duplexer" notches everything on the low side which would probably be the Syntor TX at 152.21 MHz. It would be helpful to trace out the cables and filters to see if it is one branch of notch filters or multiple. The fact that there is a 7 MHz separation between the YLD1003 receiver and the Syntor TX indicates pretty much the required separation of that filter.
At a system level, I wonder how the system prevented multiple Syntors from being keyed at same time by one portable? Was there PAC-RT logic? If so, how did it sense activity?
PASP must have later gone to Pyramid SVR200U's as I see a lot of those on E-Bay from PA.
