This is my first scanner and I cannot find out how to set it up. I live in ct and all I can get is Alaska. where and how do I start to set up this?
Try this:This is my first scanner and I cannot find out how to set it up. I live in ct and all I can get is Alaska. where and how do I start to set up this?
He selected that it's a 996XT and stated where he is...so that's a start.It would be much easier if you provided the make and model of the scanner and the system(s) you want to scan.
Plug the cable in to the PC.After some playing around I was able to delete all preloaded systems and create my own and manually input the sites I wanted. I downloaded freescan but still having problems uploading to scanner. Also trying to get ct state police, its a trunked system. thanks for the help the easy to read manual is much better! This thing is much more high tech than the old scanners I used to play around with!
